I have put GTA SA into a '.mds' format and it works, only on the setup. When I click "Play Game" is says "No Disk inserted, Please insert CD/DVD" (something like that). How would I be able to have it run? I'm running Windows XP Home w/SP2, and Daemon v.4.08.
"No Disk Inserted"
Maybe the cd have a secure system that against daemon, sometime you have to let your cd-rom off power.Originally Posted by bobbyg2 View PostI have put GTA SA into a '.mds' format and it works, only on the setup. When I click "Play Game" is says "No Disk inserted, Please insert CD/DVD" (something like that). How would I be able to have it run? I'm running Windows XP Home w/SP2, and Daemon v.4.08.
My GTA San Andreas came on a dvd and it was a Securom 7.00.00.0037
Make you image again in Alcohol 120% using a High DPM measurement and make sure that it correctly extracts the DPM. It will say in the dialog box in alcohol if the DPM extraction was successful.
Use MDSviewer after you finish dumping and it should have a nice gentle curve.
Hope this helps
what?!?!?!?!?!? I have the same prob please explain!!!!!!Originally Posted by Agro View PostMy GTA San Andreas came on a dvd and it was a Securom 7.00.00.0037
Hope this helps
