Ive observed some *very* odd behavior in daemon tools 4.08 HE compared to the last time i tried to run Diablo 2 LOD (1.11b) in win98 with version 3.47.
I havnt played diablo since i moved from win98 to winxp, which has only been about 6-9 months now. Anyway im having a really bizzare issue. It installs fine, but asks for a cd when i play. (classic problem i know, but please keep reading)
I made a cd image of all four cds quite a long time ago using clonecd. They always seemed to work, even after i updated the game to 1.11b. Back then they still seemed to work in win98 with daemon tools 3.47. I remember having some strange problem back then, but it quickly resolved itself and never manifested itself again.
I have not tried uninstalling 4.08HE with 1.39 SPTD and replacing it with 3.47 to see if it works with that version, however i know that it worked, and i know that ive used my images (.ccd/img/sub/cue) before successfully.
Anyway, Diablo 2 will (except for twice out of about 150 attempts) say "Please verify that your diablo 2 expansion disc is in your cdrom, then click on retry." It will not play from the mounted play disc, nor the mounted expansion disc.
However, when i mount BOTH the play disc, and the expansion disc, it will not give me the error. But this is *only* if i mount the play disc in a lower drive letter than the expansion.
I normally mount images in W, X, Y and Z.
If i mount the play disc in Z and the expansion in Y, it will not work.
Working:
Y: Play
Z: Expansion
Nonworking:
Y: Expansion
Z: Play
Can anyone explain this weird behavior to me? Diablo 2 with the expansion installed requires the expansion cd in order to play.. i am totally baffled as to why it requires both images to be mounted, and only in a certain order. If anyone has any ideas as to whats causing this, id love to hear em. I can play now that ive spent 4 hours trying to figure this out, but id rather figure out why its being weird so i can go back to mounting only one image.
PS: A-Ray Scanner 2.0.2.3 returns this:
[06:56:17 AM] SecuROM 5.03.13.0190 detected -> F:\Games\Diablo II\Game.exe
Working:
Y: Play
Z: Expansion
Nonworking:
Y: Expansion
Z: Play
