I used Alcohol 120 to make a mds backup of Civilization 4 DVD which apparently has SafeDisc 4.60.00 according to your database, but after creating the image it didnt work, cause the game said there was no CD in the drive or something..I was wondering if u guys know why its not working..like, what settings should I enable to make it work? With DVD's the version of alcohol I have only lets me skip reading errors and seperate the file into up to 4 gb (or not at all)- it doesnt have the database type options, or DPM, and read speed is greyed out at maximum..not so many options for DVD i guess..
O and also I created an image for the original Command and Conquer but it doesnt work, and I think its cause its so old of a game, no protection scanners can even figure out what protection it uses, but after i mount the image with alcohol it wont even work, it says no disc in drive. I know this is a daemon tools forum but the alcohol forum apparently doesnt allow anyoe to ask questions cause all there are are stikies of info and i have never seen anyone posting a topic there. So this is why i am asking here.
