This problem can probably be solved pretty easily, but i'm not sure what to do. I am trying to make a back up of my Battlefield 2 game, which the database says is protected by SafeDisc4.5 There isn't a SafeDisc 4.5 option when burning with Alcohol 120%, or at least i havent found one, and whenever i try to burn i get a lot of errors. Any help would be greatly appreciated, thanks.
A simple n00b question
First of all, you can't play a Safedisc protected game with a burned image.
Just leave all options at the image creating empty.
Safedisc is looking at defect sectors at the DVD.
Before playing the game you have to download the latest version of YASU that can be found here:
Just cloak your devices with it, mount your image and have fun
Schreibt mir eine PN!
Just to supplement a bit:
There are no profiles for DVD in Alcohol, but there are for CD.
While it is not possible to burn a workable SafeDisc DVD backup, it is possible to burn a CD one, providing a capable writer is available.
There is an Alcohol forum, where you could ask questions about it.
I just doubt that if you discovered that there were no profiles for burning, how had you made your image?
Battlefield 2 CD version
I am currently using an image with DT to play Battlefield 2 on three computers at home and twentyfour computers at a lan center. None of these are dvd (yes I legally purchased twenty seven copies, it's a big stack
I've made a copy of the all three disks of Battlefield 2 but only keep the first disk on all the playing machines.
The original image was created with Clone CD *gasp*. I have a few images made with Alcohol. The Alcohol images are apx 1 year old, the CloneCD (used clonyxxl to detect copypro) images are about 9 months old.
All made from the same machine. No emulation and no additional software is used.
copy protects xxl
Yes, I do know that clonyxxl is completely toast, I've just not bothered to change my shortcut :P I realise clone cd doesn't get updated anymore either but I seem to have more troubles with alcohol than it. :wink: I'll just have to take some more time with Alcohol 120 to figure it out.
