I have this game Need For Speed UnderGround 2 apparently uses like SafeDisc 3 or 4 I think..and also maybe some sort of CD/DVD string check, well, thats what PID said.
I tried to mount the image in Alcohol 120 AND Daemon tools With all protection options and emulation enabled, and it wont work. Then I also tried using YASU to no luck.
Any suggestions?
Any suggestions?
