Hi guys,
I've tried to copy a DVD (Howl's Moving Castle) onto my computer with alcohol 120%. The size of the .mds file is about 7.5 GB this means i can't burn it onto a DVD without buying a special DVD burner that can write such.. When I mount the image with alcohol and try to play it I get a 3min long film without any menu options etc. does anyone know what to do? Do I need to use another program to do this?
Thanks
Glaedr
Thanks
Glaedr
