Anyone know what this error is all about? I have C&C3 set to SecuRom, and it says "Conflict with emulation software detected"
Command & Conquer; "Conflict with Emulation Software"
Now I get a NEW error after downloading and installing YASU;
"Please insert the original disc instead of a backup (1000)"
Sounds fun...
So, any clues from here? I have all cloaking options enabled, and I have all of the options of DT for emulation (With or without them), and I get the error.
It does not, if VSO-Software EZ-Play is enabled, which is being installed with BlindWrite 6. If you have BlindWrite installed on your system, run EZ-play manager and remove that driver.
