Hey would like some help regarding getting this game to work. My trial of Alcohol expired so im using CloneCD now. I created the ".ccd, .sub, and .img" files but I still get insert CD errors when i mount the .ccd and try to play. is there something special i need to be doing? YASU is on btw...
Warcrat 3 The Frozen Throne
Well you could use Alcohol 52% Free Edition to create your image with SecuRom new profile as CloneCD can't read DPM which is needed here.
I prefer to buy Daemon Tools Pro which should be out in the next days/weeks.Make something idiot proof, but then they just make a better idiot
pointing to thread Another Frozen Throne thread *with magic!*
Check out my reply to this thread and then tell us the version of your RoC disc if you want to use that alternative method.the modern world:
