C&C Generals Zero Hour
  • C&C Generals Zero Hour
    This has probably been asked hundreds of times before so I'm sorry for the annoyance but.....
    I have my C&C Generals Zero Hour discs; how exactly do I create a working backup?
    Thanks.
    These Discs are only DafeDisk 4.6 Protected, so the only thing you need is Alcohol 120% to create the Image, choose SafeDisk Profile, Mount the Image in Daemon Tools and use YASU or SD4Hide to prevent Blacklistening against Daemon Tools.
    sysProfile (Click me)
      Thanks a lot Mystique
      Now what exactly is YASU or SD4Hide lol :-)
        They're both tools that will help "hide" Daemon Tools from the Safedisc guard module.
        Get YASU here:
        http://yasu.copybase.ch
          Cheers Kitna.
          Just a couple more questions -
          1. What file format should I save the disc image as in Alcohol? (mds, ccd, cue or iso)
          2. Is it normal to get A LOT of 'Read data examination errors' when creating the image?
          Link to Screenshot -
            1. MDS/MDF
            2. Yes it is normal for SafeDisc.
              Cheers Blazkowicz.
              Thanks to everyone for help.
