Hi!
I observed some really strange things I thought they're worth mentioning on this board.
I have a Flaming Cliffs ISO Image. Its no surprise it doesn't work if burnt on a CD or mounted with DT.
BUT: IF you physically disconnect your CD-drives, it does work if you access the mounted iso-image (DT 4.09) while Starforce checks the image. I tried multiple times and if you copy the Iso (anywhere you want. I copied it to the desktop) and start the application while copying, Starforce passes and the game will start with no problems.
Some additional info:
Win XP SP2
Starforce 3.7.14.2
Lock On with Flaming Cliffs 1.12a
So far. Hope it helps somebody.
Win XP SP2
Starforce 3.7.14.2
