Hello I don't know where else to post this question and hopefully it's not much of an OT.
I need to create an image file (any type supported by daemon tools) containing simple data (no need to bypass any protection). The problem is that most programmes which can create Image files can do so only using a CD/DVD as a source. However, I need to create an image with files already located on HD as the source. Could anyone recommend me a SW which can do it? Thx in advance.
