how do i play games without da disks on Daemon tools? some one said that i could. i am compl=eteley lost please help me?!?!
Sum 1 told me i can play pc games without disks on daemon tools? how?
You need Daemon Tools Pro or Alcohol 52%/120% to create the images. You need your original discs to make the images with. You need to know the copy protection used. And finally you need to choose the appropriate datatype in Alcohol or DT Pro to create a working image.
Those are the generalizations. If you need specific help, we're going to need more info, like the name of the game you want to backup, what copy protection it uses, etc.
I just backed up a copy of Halo Combat Evolved. I found out it uses SD from the Game Database but it took me awhile to figure out to use a .ccd format to get it too work. Are there certain copyright protections that only work with certain file types? If so what are they? And is there a protection scanner that will tell me the protection type and the file format to use when making the image? I'm very new to this so sorry if I'm stating the obvious.Originally Posted by Jito463 View PostYou need Daemon Tools Pro or Alcohol 52%/120% to create the images. You need your original discs to make the images with. You need to know the copy protection used. And finally you need to choose the appropriate datatype in Alcohol or DT Pro to create a working image.
