Ok, I've thought about playing some more NWN again, and therefor I pulled forth the play-disc needed(Hordes of Underdark)(Expansion)
I ran ProtectionID on ALL the .EXE files on the CD, but I did not find out what copyprotection it used, it said it either didn't have one or used an unknown one.
Help would be appreciated,
Thanks.
Thanks.
The files on CDs/DVDs are often compressed so copy protection scanners won't find out the protection.
