I need to disable XP's default burning thing because the base of it is Adeptec's EasyCD creator, which, when DT is installed, causes the system to load to a BSOD if DT is installed. If that's not the case, then it has something to do with the SCSI driver for the virtual drive (which I don't use anyway) which I can't uninstall or disable and have DT work. Please help!
Disabling XP's default burning utility
