Just Cause
  • Just Cause
    Hi all,
    This is all new to me and I would like to put Just Cause (the game)on my laptop. I found out that it is 'SecuROM' and I used the New SecuRom profile to put the game on my drive.
    When It's mounted with the Virtual SCSI I get the error 'Please remove from CD/DVD drive and insert the original disc into d:'
    with Virtual IDE I get the error 'Please insert the original disc instead of the backup' and the SecuROM switch is on green.
    So how to get this to work, I'm using DAEMON Tools Pro V4.10.0218.
    Thanks for any help
    You should get the latest YASU, it will help...
    Carpe diem
      Please insert the original disc instead of the backup - Your image is bad. Click on the link in my signature.
      Please remove from CD/DVD drive and insert the original disc into d: - Use YASU
        Thanks! I have download YASU, but how do I use it?
        Do I have to remake the image in Daemon Tools?
        I don't really want to buy more software to get this to work as i though that the full Daemon Tools would do the job.
          No, no, above are only the settings for Alcohol, in DT Pro it is just select the profile new securom and lowest dpm speed.
          You have to place yasu in daemon tools folder, start it from there and hit the cloak button.
            Ok I will need to do a new Image file, I have selected the New SecuROM profile, but i can't change the DPM speed, it will not let me?
              Strange, i hope you clicked what i show in attached image.
                My drop down box has nothing in it, look at my attached image!
                  Change your drive at device.
