Crysis Protection Type?
  • #46
    replacing exe with original from dvd, does'nt that mean 1.2 updates won't work?
    There was another thread (deleted now) which mentioned about enum reg hack? what is it?
    FYI
    PATCH 1.0 EXE
    Scanning -> \crysis.exe
    File Type : Exe, Size : 4674784 (04754E0h) Byte(s)
    -> File Appears to be Digitally Signed @ Offset 0474000h, size : 014E0h / 05344 byte(s)
    -> Suspicious MZ Header..
    [!] SecuROM Detected - Version 07.34.0014
    - Scan Took : 1.922 Seconds
    PATCH 1.2 EXE
    Scanning -> \Crysis.exe
    File Type : Exe, Size : 5018848 (04C94E0h) Byte(s)
    -> File Appears to be Digitally Signed @ Offset 04C8000h, size : 014E0h / 05344 byte(s)
    [!] SecuROM Detected - Version 07.36.0007
    - Scan Took : 1.953 Seconds
    Regard Solway
    • #47
      @solway
      As long as you see 1.1.6115 in ingame menu everything should be fine.
      • #48
        Send a PM to Niko76, he is the one that invented or wrote about the idea .. and didn't want to write it for SecuROM to see.
        • #49
          I'm having trouble getting Crysis to load correctly.
          I have DT 4.06, and Yasu 1.4 yet i always get the error, "Conflict with emulation software"
          Has anyone else been able to figure out what the issue is?
          • #50
            Also, whenever i run yasu i get the error, "Unable to located the file "daemon.dll" and/or "dtpro.dll".
            Yasu is in my daemon tools directory and works perfectly fine with Frontlines Fuel of War, but whenever i launch Crysis for some reason it cant find daemon tools correctly.
            Note by Underheaven : the forum is moderated for users with under 20 posts. We try to approve the posts as soon as possible.
            • #51
              Does not work. Still get the error "Conflict with emulation Software" from crysis. And still get the error "Unable to find controller(s) to cloak, Unable to find devices to cloak." from yasu.
              DT 4.06HE
              Yasu 1.4.7080
              • #52
                Very strange. It definitely shouldn't affect the functionality of YASU which image you have mounted
                Does your original still work with v1.2 ?
                • #53
                  Crysis With DAEMON-Tools?
                  Is there any way to use Crysis 1.21 with DAEMON-Tools 4.12.2?
                  Note from Underheaven : I moved your post here.
                  • #54
                    why donot u share ur Multi-5 language Crysis mds and mdf ?
                    • #55
                      because that's illegal, dude
