C&C 3 v.1.09
  • C&C 3 v.1.09
    I installed C&C 3 and patched it to 1.09.
    1.00 version worked fine with DT & Yasu but 1.09 says "Emulation software conflict detected".
    (That is actually a translation because my PC's language is set to finnish)
    I use DT lite 4.10 & Yasu 1.4 (Build 7080).
    Alcohol 120% is also installed, but virtual drives are enabled on it.
    Help...?
    You have to wait for an update of DT/Yasu or downgrade your DT to 4.06.
      Thank you.
      Where can I download older DT?
      I didn't see link in downloads section.
        just search with google "daemon 4.06"
