Daemon tools version 4.08HE works fine with my 1:1 copy of the 2142 iso made with alcohol 120%, wich mounts and is read on all versions, but the application does not accept the image if mounted on a version before 4.08, or after.
i've tried cloaking utilities to no avail; this is a problem for me due to my DVD drive not recognizing crysis well enough for crysis to actually decide it's the real disc, and the same for 2142. I'm not exactly sure why a newer version wouldn't work if the old one worked without a problem. Suggestions?
