FEAR: Perseus Mandate
  • FEAR: Perseus Mandate
    I'm trying to get this running without the disc but, the Securom message comes up and says to put in a valid copy. I'm using DT 4.11.2 and YASU 1.4.7080. I made the image with 52% High DPM at 24x. Here is the Protection ID info: Scanning -> C:\Program Files\Sierra Entertainment\FEAR Perseus Mandate\FEARXP2.exe
    File Type : Exe, Size : 7352320 (0703000h) Bytes
    -> Suspicious MZ Header..
    [!] SecuROM Detected - Version 7.xx
    - Scan Took : 0.703 Seconds
    This is odd because Crysis even works.
    Your image is bad. Try to lower your DPM speed.
    Also update to Protection ID XMas Beta
      Tried 8x and still no good so I will try 1x on high. Newest Protection ID says SecuROM 7.33.0016.
        So it does its job
        sysProfile (Click me)
          What burner do you use? For me, FEAR PM works with dt.
          Schreibt mir eine PN!
            Well, tried it on 1x high DPM with 52% and it still didn't work. But I was storing it in the same folder as my Crysis backup and had the idea that maybe it would like its own folder so I moved it and it worked. I'm not sure if this is common but it worked for me.
