Hi, i'm not quite sure if i'm in the correct section, if not please move this to the correct corresponding place, thank you.
I recently dug up my old starcraft & broodwar iso images and installed them. Everything was fine until i try to run broodwar, i managed to installed it but cant play with it.
I did a search and tried every suggested way. But nothing works. This included:
1. Switching the directory letter to an earlier one (from E: to D
to accomodate older games.
2. Getting ProtectionID to scan it
3. Getting the latest D-tools 4.11.2
4. Playing around with emulation options
As far as i know there are no protection for SC & BW, the scan from PID reveals nothing. Starcraft's ISO runs fine but Broodwar's just giving me headache. I read about installing and playing from the same directory but i dun really get it.
Any help will be deeply appreciated. Thanks.
to accomodate older games.2. Getting ProtectionID to scan it
