I have Daemon Tools Pro Basic(the newest version available) and I'm wanting to use it for Playstation backups. Well, I've read in other threads that you should make these images with other programs(such as Alcohol 120%). I don't have a problem with doing this, but the main reason I want to use Daemon Tools for them is for the compression. I can use them well enough by just adding them to Daemon Tools after making them with Alcohol, but Daemon Tools doesn't provide a method of compressing the image unless they're being ripped from a disc. I tried mounting the image in Alcohol and ripping it through Daemon Tools, but all of the plugins cut essential data from the backups. So, what I need to know is if there is a way to compress already ripped images or if there is a way to make Daemon Tools rip the RAW data from the CDs. Thanks for any help.
PSX ripping/compression
You should be able to rip a cd and keep all the subcodes. Maybe try some variations of the securom profiles.Originally Posted by bcrew1375 View PostI tried mounting the image in Alcohol and ripping it through Daemon Tools, but all of the plugins cut essential data from the backups.the modern world:
