Is DT pro advanced v4.12.0223 capable of dealing with SF 5.5 ?
  • Is DT pro advanced v4.12.0223 capable of dealing with SF 5.5 ?
    Just wondering if it is possible to play games protected by this shit =)
    scan reveals this:
    Host your images online with an easy to use image uploader, albums, photo hosting, sharing, dynamic image resizing on web and mobile.
    any suggestions? or it is hopeless
      That version of StarForce is blacklisting DT Pro. You could try to burn a RMPS copy which i read it should work with SF 5.5.
        Any hope to get DT's update soon?
          Thank u. I should try this
            Can you tell me which program is needed to burn RMPS copy? DT Pro can't do this...
            Vesdaris, Turgor have SF 5.0, but not emulated anyway.
              Alcohol 120% can do that.
                RMPS don't do the trick...
                  Same systems (winxp sp3, vista sp1). Same reader. Same burner. Same dvd-r. Same person .mds normalized in tool from blindwrite suite.
                  "Provincialnij igrok 3" (SF 5.5.6.2) works fine from dvd-r.
                  "King's Bounty: Legenda o ricare" (SF 5.5.8.2) Very long checking with result "wrong disk ..." at 90% and bsod after few seconds with 1.56 sptd. With 1.50 wrong disk at 40%, but no bsod.
                    try SPTD 1.53 and tell us result.
                    • #11
                      Ok. DT 4.11 SPTD 1.53.
                      King's bounty (SF5.5) makes a BSD after telling the disk is wrong with and without emulation options.
                      As for Tension(Tyrgor) with the older SF - it goes far enough checking the disk without emulation options, but failes around 40%. And there is a BSOD with emulation options.
