other game databases
  • other game databases
    Hi.
    I know about programs that detect copywrite protections, and I know about Daemon's game database. But can people give me some links to some of the other game protection databases out there that are the best?
    Thanks
    vze2mss6
    the best is ours of course
    Seriously, there are soon some updates to our game-database,
    we remove orphaned entries and add all the latest known protected
    games
      Another site which is also best
      Your daily source for insights across every topic that matters
        what do you need such a databse for anyway? simply scan the game disc / executables yourself using ProtectionID!
          Well, you can scan some games on install first and not before install and if you just look at game database, get the right copy protection and then you could create a working image from the scratch and can install with that created image.
            http://copybase.org/datenbank/
            It isn't, but it was and it soon will be again .
            MfG, Benni
            Mail: benni@copybase.org
              Does that mean it will soon be available in English too? (hint hint)
                Yes, it will.
                MfG, Benni
