SecuRom v4.85 protected game - can't get image to work
  • SecuRom v4.85 protected game - can't get image to work
    Hello! I'm trying to make an image of a SecuROM v4.85 *new* protected game but the image doesn't seem to work. The game won't play.
    I created the image using Blindwrite 5, and enabled RMPS emulation. Any ideas? I guess i could play from the original cd (which works fine) but i like using cd images to save cd switching all the time.
    What is the game and are you using bw5mount plugin?
      Worms3D, and i'm using the bw5mount plugin
        Do you receive error mounting or you just get 'insert cd' error?
        You shouldn't need rmps emulation when playing from an image.
        Can you email me your b5t file to andareed@daemon-tools.cc?
          It's a strange problem - there's no particular error message, it just fails to start. After you click the launch button it waits a bit and then nothing happens - during this time you get the 'busy' mouse pointer. I presume this pause is when the SecuRom check takes place; if you are playing from the cd you hear it spin up a little, then the game launches.
          I'll send you the file
            Probably the already known blacklisting of the virtual drive. Moreover RMPS emulation is not needed from image.
              I tried it both with and without emulation but it didn't work either way. Is there a way to get round the blacklisting or is that impossible?
                You'll have to wait for next Daemon Tools version.
                  thanks for the info
                    I Guess im having the same problems....? :arrow: http://www.daemon-tools.cc/portal/viewtopic.php?t=1778
                    "BACKUP RIGHTS"
