OK, Mass Effect PC uses SecuROM's online authentication. But I also notice that the disc still has the usual "rings" associated with disc based SecuROM. I have used Alcohol to create the image and extracted the MDS for the disc. Sure enough, upon inspection it does have four SecuROM "rings" like any other normal SecuROM game.
Does anyone know if the online activation checks the disc ? (I know the disc is not needed after the initial online check.)
When it did the initial check it took a few seconds and I did not see the usual SecuROM "spinning disc" animation at all. So either they changed that method or it doesn't check the disc. But if they don't check the disc during the initial online authentication and still have the four rings, which cost money, that means they have prepared a backup plan for later on ?!?
