Hey Guys,
i'm trying to create a backup copy of "Mediscript GK1 03/2008". It's a medical e-learning software, which is protected by "Protect CD" / "Protect Disk". I'm not able to determine the version of the copy protection: Both ProtectionID and A-Ray report "no copy protection found" after scanning the cd.
I tried it the following way:
- Create an image (mds/mdf) with the latest Alcohol 120% using "Protect CD V5"-Profile and DPM-Precision HIGH
- Uninstall Alcohol and other emulation software
- mounting the disc using the latest Deamon Tools - all emulation options activated
The program is refusing to start and reports active emulation software running.
Protect Software - Emulator active
Is it possible to avoid this blacklisting?
thx in advance
thx in advance
