1:1 Copy???
  • 1:1 Copy???
    Doesn't 1:1 mean just Copy CD? I made a copy of Rollercoaster 2 CD and it looks just like the original but I do not know what you mean by mounting Image since The copy has the same Files as the Original Disk. Which files do I need to mount? Thanks
    If I not wrong, 1:1 copy is raw mode copy method. It's not the same as normal cd copy. Normal cd copy could not copy some 'thing' that some protection implement.
    About mounting file, you need an image file of a CD. You must create it first eg: with Alcohol120%, Blindwrite, CloneCD, etc.
