Hello!
I just wanted to ask quickly if its Possible that the DT Pro Advanced is being Blacklisted by that Securom Version?
Reson i ask is i have a Game called "Die Siedler - Aufbruch der Kulturen" which wont work in any Form with DT. If i Mount Image or if i reburn The image wont make a Difference even more so i tried Several Versions from DT and Yasu etc
However my Copied Image works perfectly fine if i run it with VirtualCD instead and deinstall everything else.
regards
regards
