Hi all
I have a plextor DVD-RW Px-755SA.
I'm trying to copy my CDs application.
I scanned it with all scanners and no protection found...
the CD protection of an application that comes with 2 CDs
1 CD is the install of the application that have no protection the 2nd CD is the DB of the application.
in the protected CD there are 3 files with a XXX extension in root:
file00.xxx - 563,438 KB
file08.xxx - 850 KB
file09.xxx - 3KB
there is 2 more folders
MA folder files:
file08.MA - 1,054 KB
file09.MA - 36 KB
YZ folder files:
file08.yz - 361KB
file09.yz - 11KB
i saw that in CD freaks forums it was also an issue with somthing that seems to be the same protection :
hxxp://club.cdfreaks.com/f18/defekte-sektoren-ab-316687-a-72880/
i have try to image the CD with all application (blind write , CloneCD , game jackel , Alcohol with all profiles also DPM) and when i try to run the images the application of the recognize that it's not the original CD (used latest Daemon tools and Alchol)
I have run Olly with BP on ControlIoDevice and found out that header :
CD001 GEAR CD/DVD PREMASTERING GEAR SOFTWARE 200703201349480020070320134948001983032013032200 2007032013032200
so now i know what was the app that they use for PREMASTERING but still i can't find why the image is diffrent from the original CD...
can any one help me to how can i make a good clone of my CDs ?
file08.xxx - 850 KB
file09.xxx - 3KB
MA folder files:
file09.MA - 36 KB
YZ folder files:
file08.yz - 361KB
file09.yz - 11KB
