Strange - i and many users can have their real drive connected and it is working.
Mark of Chaos: Battle March Safedisc 4.85
Depending on your hardware some or none of the following methods might work:Originally Posted by KainofNosgoth View PostIs there anyway to get around having to unhook my real optical drive?
- deactivate the IDE channel your optical drive is attached to in BIOS
- deactivate your optical IDE drive with Starforce Nightmare 1.12 (some info in this thread)
- deactivate your optical IDE drive or the IDE channel your optical drive is attached to in device manager
- try YASU
After every failed attempt reboot and try again.I'm not employed by Disc Soft and my views do not necessarily reflect the ones of the company.
I tried all of the above methods but none of them worked! Are there any other ways? Am I stuck to buying an external DVD drive???Originally Posted by Terramex View PostDepending on your hardware some or none of the following methods might work:
- try YASU
Or a case to turn your internal DVD drive into an external. I did just that a few years back, haven't had an internal drive since. Of course, back then it was a lot more common to have to unplug your DVD drives, and I just never bothered to put them back in.
I moved the non-related posts of this thread to Drive suggestion - Page 2 - THE DAEMONS HOMEMake something idiot proof, but then they just make a better idiot
