Help
I can't run my image. It was taken using clone cd and has a .bin and .cue file. I mount the .cue with DTpro 4.30.0304.0047
PID tells me it is using safedisc 4.81.000 protection
I have tried playing with the advanced options e.g RMPS, Safedisc etc under the advanced options menu. However everytime I try to run the application I get the error
"Please insert the correct CD-ROM, select OK and restart applicaiton"
Any suggestions?
I am using XP SP3
Any suggestions?
I am using XP SP3
