Hello folks, I've got a problem with SecuROM 7.36.0007
I can't make a copy of my CD (BoatDriverSwiss Ver 2008)
This programm is for learning how to sail, the special part about all this is, that the programm doesn't need an installation it starts from the CD.
I can make an image with Alcohol 120%, which works finde when I use it in a virtual machine in VMware Workstation 6. But when I use it in a DaemonTools or Alcohol 120%, it recognizes the emulator and it doesn't start. I tried several tools like SD4hide, Starf***ker, Y.A.S.U, none of these seems to solve this.
When I burn the image on a CD, it doesn't work at all, not even in a VM machine.
I've read quite some threads in different boards, but this case that the program doesn't have to be installed, I couldn't found
Anyone have a suggestion, what I can try more?
PS: I'm Swiss, so there might be some faults into the text :wink:
Thanks for your help
Copyfreak
Copyfreak
