Stronghold: Crusader problem
  • Stronghold: Crusader problem
    i copied my stronghold crusader disk with virtual drive, but whenever i try to play the virtual disk it tells me to enter the real copy not a backup. It says its protected by secuROM. how can i get around this?
    Bad image, you need DPM info.
      i dont know how to do all that stuff. anywhere i can learn?
