clonecd(newest) image problems
  • clonecd(newest) image problems
    i made a cd image of my worms 2 cd but when try to mount it with newest daemon tools it says "Unable to mount image. Invalid ADR field detected."
    When i created the image it created it with out any troubles.
    What settings did you use?
      i just used the defaults for protected pc game preset.
        Iirc, there were some changes made to ccd mounting since 3.41 (internal betas). Can you email your ccd to andareed@daemon-tools.cc and I'll look at it?
          Simply one of the CCD entries has an adr=0x05 or difetent but not 0x01.
