I'm trying to play Might and Magic 8 and 9 and particularly with 9 I got everything installed and it ran off the image (which is an ISO) perfectly fine, but when I run the actual executable it just doesn't see the cd and gives the "please insert the correct CD-ROM, click OK and restart the application" error. I really just want to play the game and seems like this should have been easy enough to fix, but alas I have yet to figure out how. Help anyone?
Another "Please Insert The correct CD-ROM, click OK and restart the application"quest
I believe Might and Magic 8 & 9 both have the original Safedisc on them so i got unsafedisc for them, and in all honestly cant figure out how to use it. Is there something better than that? And I own the discs but they are in storage 4 states away and wont be able to get them for months, but I wanted to play now! =). So is safedisc what is directly causing the game not to recognize the image that is mounted on the virtual drive? am I missing something? Should I be using a different piece of software? Thanks!
the issue is (from your own statement) that the image format is iso.. which is totally USELESS for protected disk images...Originally Posted by Forumhelper View PostSo is safedisc what is directly causing the game not to recognize the image that is mounted on the virtual drive? am I missing something? Should I be using a different piece of software? Thanks!
so, you've got no real option really
to play the game -> get the originals and play
to play the game using a virtual drive -> get the originals, make an image (NOT an iso file) -> play
either way, both kind of mean you need to get the original disks back.... catch-22my views are 100% personal views..
