Call of Duty v 1.4
  • Call of Duty v 1.4
    Hi guys, I've been trying to figure out how to emulate CODWAW for ages, I have the iso, but no matter what I try, it doesn't work. According to the database the protection is SafeDisc 4.90.010, what can I do?
    ISO will not work, you have to recreate your image with DT Pro.
      Omg ty, I'll give it a go.
        Select the SafeDisc profile in DT Pro for image creation.
        After creation is done, mount the image and then run DTE and cloak SafeDisc.
          Cheers, I can't wait to pwn some zombies .
            Is it possible to do it from an iso, not from a physical disc?.
              No, ISO doesn't contain any protection data, therefore not possible.
