I am trying to play Sim Themepark (yes, from 1999. :] ) and I have installed it with DT Lite.
I tried playing it using the desktop shortcut, and I got the familiar, dread-inspiring message: Please insert the correct CD-ROM, select OK, and restart application. I searched this forum and read advice to get DT Pro, which I did, and install it to an IDE. Still doesn't work. If I try using the Autorun program on the disk, it says "C:\WINNT\Start Menu\Programs\SimTheme Park\SimTheme Park.lnk. The specified file was not found.
The file is an iso format, if that helps...
Thank you, and I would appreciate it if the answer was in plain, broad english. I don't speak much computer. : [
