Ok, so daemon tools lite is running, I mounted the ISO file to the virtual drive. I'm trying to play diablo 2, but when I click the icon it says "please insert disk"
when i click the daemon tools icon in the try it reads
device 0: [f] c:\users\owner\diablo2\expansion.iso
so i know its mounted correctly.
I dont know what the problem is. The game worked fine for a while, but i havent played it in a good 3 months. If someone could shed some light on my problem I'd be very grateful.
Also diablo 2 is still installed on my machine, and i can't test the original disk because it broke, which is why i used daemon tools in the first place
