Just to pre-cursor this, I have read EVERY Oblivion post across the entire web on this issue and can't find an answer.
I am having issues with my SecuROM infested Oblivion backup Setup.exe (and OblivionLauncher). It is not detecting emulation software (I know, because I put in my original disc in while running Daemon/Alcohol 52 [I even had each one mounting a backup image of oblivion while doing this] and launched setup.exe and it worked fine).
It is the fact I am using a backup iso/mds (I have tried both) and it is detecting that the original is not being used. I get the error: "Please insert original disc instead of backup (1000)".
I have gotten this to work once in the past and for the life of me can't remember what I did. I started using backup disc for EVERYTHING because I reformat quite often and got tired of changing out disc (also I like to play without having a disc). So it was a pain tonight dragging out of storage my old disc to make sure this actually worked and even trying to create new images multiple times. If anybody else has gotten this to work let me know.
