I'm backing up my DVD discs, and used Daemon Tools Image ripper to make an image of "Thank You for Smoking." I try to play it in the virtual drive created by Daemon Tools, and it won't play as it says it wasn't made for this region.
The default region for Daemon Tools Lite is "Not Selected" under the drive options (by going to "My Computer" clicking properties and then selecting the drive). I changed it to "Region 1" as that is the US region and thats the region I'm in, but still I get the region error issue.
Do I just need to re-rip the ISO now that its set to Region 1? I may (depending on whether or not I lose the disc) have to burn the image file, so I want it to play in my Denon BD player too.
Or is there just a way to set the disc to Region 0? Or "No Region?"
