SecuRom Old version.
  • SecuRom Old version.
    Hi
    I have an original set of UK Info Disk v4.1 released in May 1999.
    It is copy protected with SecuRom.
    When I install and run with disk 2 in the drive I get "wrong disk inserted"
    I think this is because the SecureRom version is so old and my CDRom Drive / PC so fast that they are both incompatible.
    How can I tell from the files on the CD what version of secureRom this software is protected be. I have tried many of the copyprotectid programs but they fail to give a version number. Just Securom old V3 or below?
    Any help please ?
    Does the program completely run from CD or do you have to install files on the HDD ?
    If there is an installation check the install path with ProtectionID.
    Which OS are you running ?
    If Vista, try to run the executable in different compatibility modes.
      UK Info Disk v4.1 (1999) (Old SecuRom)
      Thanks for the reply.
      Its a two disk set. Install CD and Data CD.
      The Install CD creates the a dir on c: with these files:- And requires the second CD to run not only for copy protection but the CD also includes the Data for the program.
      The install directory copied to c\ contains the following :-
      17/05/1999 10:13 11,587 c01.doc
      19/01/1996 09:00 455,168 c4dll.dll
      07/03/1998 16:10 51,200 Cki16_a.dll
      07/03/1998 16:10 184,832 Cki3203.dll
      07/03/1998 16:10 110,592 Cki32_d.dll
      15/08/2009 08:06 12,050 cms16.dll
      15/08/2009 08:06 22,643 cms32_95.dll
      15/08/2009 08:06 28,486 cms32_nt.dll
      19/03/1998 21:02 85,289 Crp9516a.dll
      07/03/1998 16:10 23,552 Cryp95a.dll
      16/12/1997 21:33 250,880 Ctreestd.dll
      13/05/1999 09:09 1,507,328 d1v4.dat
      13/05/1999 09:09 778,240 d1v4.idx
      13/05/1999 09:18 188,416 d4v4.dat
      13/05/1999 09:19 163,840 d4v4.idx
      14/05/1999 06:36 1,286,144 d6pav4.dat
      14/05/1999 06:44 483,328 d6pav4.idx
      14/05/1999 04:44 29,155,328 D6v4.dat
      04/04/1999 12:47 1,880,671 Dd.dat
      02/05/1999 10:10 61,440 Ei1.dat
      02/05/1999 10:10 81,920 Ei1.idx
      01/05/1999 12:27 1,024,000 Ei2.dat
      01/05/1999 10:46 122,880 Ei2.idx
      01/05/1999 10:32 364,544 Ei3.dat
      01/05/1999 10:32 122,880 Ei3.idx
      01/05/1999 10:36 57,344 Ei4.dat
      01/05/1999 10:36 122,880 Ei4.idx
      01/05/1999 10:38 297,111 Ei5.dat
      01/05/1999 10:45 81,920 Ei5.idx
        Please scan the install directory (+ sub folders) with ProtectionID.
        Which operating system, please ?
          ProtectionID Protection Report (txt format)
          14:04:27 | F:\UK Info Disk 4.1\Cki3203.dll | Possible CD/DVD-Key or Serial Check
          14:04:28 | F:\UK Info Disk 4.1\cms32_95.dll | Petite v1.2
          14:04:28 | F:\UK Info Disk 4.1\cms32_nt.dll | Petite v1.4
          14:04:28 | F:\UK Info Disk 4.1\Ctreestd.dll | Possible CD/DVD-Key or Serial Check
          14:04:31 | F:\UK Info Disk 4.1\UKid.exe | SecuROM (very old.. v3 or less) | Petite v1.4
          Windows XP
            Windows XP
            Though i suggested to try that if it's Vista:
            Please try different compatibility modes (Rightclick on the UKid.exe -> properties,
            click the Compatibility tab and check 'Run this program in compatibility mode for:',
            try the modes in the drop down menu)
              definately securom, haven't updated those files in protection id yet, cos they're sooooo old, and if i remember right petite hides a lot of the identifiable patterns think it'd be securom 3 or lower, so protection seems correct
              compatability mode for windows 2000 if possible might be the best option
                Thanks for your help.
                I tried both a run as and a clean 98 and then 2000 box and still came up with the "wrong disc inserted error". I tried a number of SecuROM loaders but none of them recognised the version of SecuRom.
                Just as I was about to give up. I discovered a network install which installed a copy of UKID.exe minus the Securom wrapping and let me copy the contents of the second disk to hard drive. Just what I want it to do !!
                Here is the results of both files (they were both called ukid.exe)
                00:45:01 | C:\Documents and Settings\_\Desktop\New Folder\UKid.exe | SecuROM (very old.. v3 or less) | Petite v1.4
                00:45:01 | C:\Documents and Settings\_\Desktop\New Folder\UKid Network.exe | Possible CD/DVD-Key or Serial Check
                Again thanks for your help. I might of given up otherwise.
                  UK Info Disk v4.1
                  the s/w is not available on amazon nor ebay. is it possible to get it from you?
                    I have the same original UK Info Disk 4.1 and get the same problems. Did you get it to run in the end?
                    • #11
                      4.1 Issue resolved
                      I bought several versions of UK Info including 3.1, 4.1 and 5.1 and suffered the same problems.
                      Hi
                      Any help please ?
                      Here's how I fixed it:
                      Firstly, your computer must be running Windows 95.
                      Secondly your computer hardware must be comparable with what was available in the late 1990s. In those days pc's ran at clock speeds of 75-400 MHz and CD Rom drives were 8 speed or there abouts.
                      We found some 10 year old hardware (2002) and put it together but then slowed the clock speed down to 300 MHz. The wrong disc problems then disappeared.
                      UK Info 4.1 was built to run on a Windows 95 computer and windows 95 was built to run on hardware that was available in the late 90's like a DX4 100, a P 75, a P 100 etc.
                      Hope that helps.
