OK I'm somewhat new at making DVD image, and i need a bit of help.
Basically, I installed TES4 on my desktop with the original DVD, no problem there, then made an .ISO file using DT Lite to play it.
I have no problem at all playing it and everything is working fine.
Now here is the bug, I transferred the three .iso file (since there is 3 DVD) on my laptop, if i get in the mood to install it, and I leave it like that.
Now 3 days later I decide to install it, so I mount the .ISO and this SecuROM message pops up asking for the original DVD.
From my search on the forum, I got that my .iso made with Lite could be the problem, but I dont have the DVD with me right now, as I have left it at my place and I'm at a friend (2h drive from home -.-) and I'd really like to know if there is a way to modify the current .ISO so it would work, or avoid secuROM checks.
Also if I am to redo the image (i now have the trial version of DT pro) what would I have to do to ensure it works?
Might be useful to know ive activated the emulation for securom, but i got no idea how it works if there is something more to do than checking a box.
Thanks in advance
A total newbie at creating virtual Image.
Thanks in advance
