Kernel debugging??
  • Kernel debugging??
    I'm using Windows 7 (32 bits) and I've installed SPTD 1.62 but DAEMON TOOLS doesn't work.
    The error message says:
    This program requires at least Windows 2000 with SPTD 1.60 or higher. Kernel debugging must be disabled.
    Is this an upgrade from Vista to 7?
    Have you checked help documents at our help site?
      Yes, it's an upgrade from Vista to 7.
      I've read DAEMON Tools Lite Help: Installation but I found no tip here. I really don't know what I'm looking for so I can't search
        I meant this help document.
        You get linked to its root document from DT Lite help there.
          I've read DAEMON Tools Professional Help: Registry and SPTD problems but this is toooo advanced for me. I give up on Daemoon tools..
          G'night!
            Just follow the guide (easy to follow it).
            Alternatively try to install DT Pro, if i'm not mistaken Pro setup has already taken care of that issue.
            BTW which security software do you have?
