I converted my Virtual FF7 disks to .iso however the game still would not play it would say "please insert disk 1, 2, or 3.
So I decided to try a new program to see if that would work Alcohol 52% worked like a charm. Now however I am at the end of Disk 1 and it is asking for disk 2.
I go out and try to swap the virtual disks and return to the program but it will not recognize the swap.
Any help? If you can help me run the game on Deamon tools perhaps that would work better.
Thanks
-Jane
Thanks
-Jane
