Looking for disk
  • Looking for disk
    I'm trying to load my iso image of Adobe Master collections and it won't install as it's looking for a disk to start from?
    Any help would be appreciated
    Running Windows 7 64 bit Ultimate
    How did you create your ISO file?
      Using Roxio 9, I can put in the serial key ok and get past the costume or typical install, but when it starts the installation it comes up with please insert disk into drive "j" where I've mounted the ISO?
        Is it working fine with original disk?
