Hello everyone!
I recently made a backup of NFSU using Alcohol 120%. When I try installing the game off the backup CD's, I get an error copying file..I can install it just fine off my original CD's but I want to be able to install it off my backup CD's as well. I was wondering if using Daemon tools to mount the image will work.
Edit: I tried to make the backups again and I get the same problem.
