I have a CD burning prog that can make ISOs, but I noticed that it doesn't copy the disk only it's files, and when I compare the Real CD to the mounted image it's not the same in mb.
What's a good ISO or CD image maker thats either Free or Free to Try. I havn't the money to spend on a product yet.
My Test subject is The Sims Deluxe Edition. I figure there is copy protection. Does it hurt to use all 4 emulations at the same time?
Thankyou for you time.
Drezliok
Drezliok
