Hi everybody i have the latest version of DT Lite(4.35) and YASU(1.6.9040). When i extract it in to C/ProgramFiles(X86)Daemonlite it gives the error first i don't have permission to access this file, i administrator by the way. I was able to bypass this by going to props and enabling run admin always. After that however i then get unable to locate daemon.exe or dtpro.dl. I tryed renaming the daemonlite.exe to daemon.exe and i still get it. I'm also trying to run Oblivion with DTLite and when i run setup the error message pops up saying that this program might be a 32bit program and that i should try and find a 64bit version??? What may be causing these issues?
