blazblue: calamity trigger
  • blazblue: calamity trigger
    i'm interested to know if anyone has created an image of blazblue: calamity trigger.
    i tried images using the data disc, safedisc and securom profiles, using different drives/speeds.
    What protection is the game using?
      Scanning -> C:\Program Files (x86)\ARC SYSTEM WORKS\BLAZBLUE -CALAMITY TRIGGER-\BBCT.exe
      File Type : 32-Bit Exe (Subsystem : Win GUI / 2), Size : 4358584 (04281B8h) Byte(s)
      -> File Appears to be Digitally Signed @ Offset 0427000h, size : 011B8h / 04536 byte(s)
      [File Heuristics] -> Flag : 00000000000000001000000000000100 (0x00008004)
      [!] Games For Windows Live detected !
      - Scan Took : 0.813 Second(s)
      Scanning -> C:\Program Files (x86)\ARC SYSTEM WORKS\BLAZBLUE -CALAMITY TRIGGER-\BBCTStart.exe
      File Type : 32-Bit Exe (Subsystem : Win CUI / 3), Size : 3137976 (02FE1B8h) Byte(s)
      -> File Appears to be Digitally Signed @ Offset 02FD000h, size : 011B8h / 04536 byte(s)
      [File Heuristics] -> Flag : 00000000000000001100000000110110 (0x0000C036)
      [!] Themida v2.0.1.0 - v2.1.2.0 (or newer) detected !
      [i] Hide PE Scanner Option used
      - Scan Took : 0.875 Second(s)
        Iirc Themida is a reversing protection only.
        Have you possibly also tried other apps capable of skipping defective sectors to pinpoint if it's only DAEMON Tools having problems with that disc ?
          i know, but i still posted the two exe "finds" just so blaz could see what was found. best i can tell, it uses no major c/p technology on the disc.
          yes, alcohol. same thing.
          18:48:45 DVD Source Info: Session: 1, Track: 1, Length: 4.97 GB / 2608448
          18:48:45 Writing image file: D:\!BURN.DVD\BlazBlue - Calamity Trigger.DVD\bbctdvd.mdf
          19:01:27 Disc read error at: 2603453
          19:01:27 Disc dumping failed!
          19:01:27 Error message: [03/11/05] - L-EC Uncorrectable Error
          19:01:27 D:\!BURN.DVD\BlazBlue - Calamity Trigger.DVD\bbctdvd.mds: Image file writing aborted!
            the 1st box is shown if there is NO disc inserted.
            the 2nd box is shown after checking a "bad" image.
            someone should be clued what protection may be on the disc by the 2100/1503 codes.
              does anyone have a solution yet ?
                ok, i just want mention that a successful image can be created, using alcohol when, for example, i select the skip reading errors option. the problem is that, the image does not bypass the disc check. i say this because my initial post might have been interpreted as no image could be completed. it is true that using most pre-made profiles it does fail to actually create the image, but it is possible to finish making an image.
                anyway, the game creates a small log. the code02 is written on the disc around the lead in area, the same place where starfoce places it's serial number.
                this log shows when no disc/image is inserted:
                [OS_VERSION]
                Os=Professional (Build 7600)
                [DRIVE_NAME]
                DriveCount=3
                0=Sony DRU-900
                1=ASUS DRW-1814BLT 1.14
                2=PIONEER BD-RW BDR-205 1.04
                CurrentId=25
                CurrentName=
                [ERROR_CODE]
                Code=2100
                [USER_ACCOUNT]
                Account=Admin
                [CODE]
                Code01=2763242688
                Code02=DCXAC105BD3931530CHD
                Code03=5205V25030000
                Code04=1
                'û
                this log shows when image is inserted, and fails the check:
                [OS_VERSION]
                [DRIVE_NAME]
                DriveCount=3
                0=Sony DRU-900
                CurrentId=0
                CurrentName=Sony DRU-900
                [ERROR_CODE]
                Code=1503
                [USER_ACCOUNT]
                Account=Admin
                [CODE]
                Code01=2763242688
                Code03=5205V25030004
                Code04=1
                  looks nobody plays the game or isnt disturbed inserting the disc all the time. If anyone can fix the problem... PLZ report ! ! !
                    Fritz, I do have the game ordered and have to send it to the devs soon due to non-supported protection.
                    EDIT:
                    Proper image creation settings can be found in this thread: http://forum.daemon-tools.cc/f18/can...trigger-31902/
