Rosetta Stone + Windows 7 + Daemon Tools Lite
  • Rosetta Stone + Windows 7 + Daemon Tools Lite
    I'm not sure if this is the correct place to post this, but I'm just putting it where I had found another RS thread...
    I'm having some issues getting RS installed on my new laptop. More specifically, I'm having issues with the language packs. I've gotten the application installed fine by using 'troubleshoot compatibility,' but when I go to add a language, RS can't detect my mounted ISO for the pack. And all that happens when I mount or try to do anything with the ISO is that it opens a window with all of its folders.
    I'm getting frustrated because this installed perfectly on my XP desktop a while back, but I can't get it to work with Windows 7. Help, please?
    Good news! I got it to work this morning :] Not quite sure what I did differently, but it worked.
